445
设想将喷油泵和喷嘴合成一体,省去高压油管并获得高喷射压力。研制出适用于乘用车的电磁阀控制泵喷射系统。泵喷嘴的结构如图3所示。其中主要部件作用如下:
(1)单向阀:发动机不工作时,防止燃油回流。
(2)旁通阀:若燃油内有空气,则通过此处排出。
(3)节流孔与过滤器:收集、分离供油管内的气泡。
(4)限压阀1:调节供油管内压力大于0.75MPa时打开。
(5)限压阀2:保持回油管内压力在0.10MPa。
(6)燃油泵:燃油泵是间歇式叶片泵,其优点是在较低发动机转速时也可供油。泵体内油道使油泵转子始终处于被燃油浸润的状态,从而可输送燃油。
(7)燃油分配管集成:燃油分配管集成在缸盖内的供油管内,其功能是等量向各泵喷嘴分配燃油,在此,燃油与受热燃油混合,并被泵喷嘴强制流回供油管。使供油管内流向各缸的燃油温度一致。所有泵喷嘴被提供相同量的燃油,使发动机运转平稳。否则,泵喷嘴的油温将会不同,并且泵喷嘴被提供不同质量的燃油。这将会使发动机运转不平稳并将在前几个缸中产生极度高温。
We hereby sincerely invite you and your company representatives to visit our booth at D236 in Hall A1, We look forward to seeing you there!
On behalf of China-Lutong Parts Plant, We hereby sincerely invite you and your company representatives to visit our booth at The 133st China Import and Export Fair from 15th April to the 19th April 2023. Our information about this event is as follows,
China-Lutong is one of the most important Chinese companies in the distribution and manufacturing of parts, components, and PODGK po@china-lutong.net equipment for diesel fuel injection systems. Based on the principle of honesty, credibility and mutual benefit, our company always adhere to promote mutual advantage by joint efforts.
If you’re attending, we’d love to see you there. Come visit us on our Booth L21 in Hall 6.1 at Canton Fair 2023. We expect to establish a long-term business relationship between our two companies
W imieniu China-Lutong Parts Plant, niniejszym serdecznie zapraszamy Państwa i przedstawicieli Państwa firmy do odwiedzenia naszego stoiska na 133. Targach Importu i Eksportu w Chinach w dniach 15-19 kwietnia 2023 r. Nasze informacje na temat tego wydarzenia są następujące:
(8)燃油冷却泵:使冷却液在冷却环路中循环。当燃油温度达到70℃,发动机控制单元通过燃油冷却泵继电器将其接通。
在国内很多的乘用车上使用泵喷嘴,如:宝来TDI、途安TDI和奥迪TDI等。泵喷嘴技术相对于之前的技术(如柱塞泵),已经具有明显改进,而其的好处是增加了喷油压力,其涡轮增压泵喷嘴的喷射压力都能达到200MPa以上。由于喷射压力直接影响柴油燃烧做功效率,因此,泵喷嘴的燃烧效率。
